Error 1 When Using Create Rendezvous With NI-488.2
Updated May 31, 2023
  • NI-488.2
I'm using the Create Rendezvous VI in my application but it gives me the following error when trying to run:
Error 1 occurred at Create Rendezvous.vi ,
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path
might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
This error can appear if you are setting the "return existing (F)" terminal to true and you haven't specified a name for the rendezvous.
Change this input to false and the VI will generate the rendezvous if none have been created.
