It is also possible to disable the rack mode to configure the IP address of each couplers or testers inside a rack.
To do so, please refer you to the MP300 UC user manual and refer you to the description of the API
MPS_EESetConfig or its associated remote command EESC
After having disabled the Rack mode IP address of a coupler or tester can be checked when using
MPS_NetworkGetAddress API or its associated remote command NMGA
Assignment of an IP address can be done when using
MPS_NetworkSetAddress API or its associated remote command NMPA.
For any additional questions please contact NI technical support team on NI.com when opening a Service Request case using the NI Service Request Manager (SRM).
To open a service request on NI.com please follow the steps described at this link.
