Create Script Using 848 kbit/s Data Rate
Updated Aug 15, 2020
  • Micropross Accessories
Other
SW: MPManager
HW: MP500 TCL3
I am trying to create a script using the MP500 and MPManager that uses the 848 kbit/s data rate. The Configure > Card Emulation step only goes up to 424 kbit/s.
Can the MP500 TCL3 reach 848 kbit/s?
Yes, the MP500 TCL3 can communicate a 848 kbit/s. You will simply need to use a Contactless Common > Select Data Rate step as shown below.
Be sure to change the command parameters to reflect the 847.5 kbit/s data rate.
