I'm interested in developing a LabVIEW application that requires the IRIG-B protocol as the synchronization method. What NI hardware is compatible with IRIG-B?
You can use PXI/PXIe-6683 in your LabVIEW application, to control this board your should install the NI-Sync driver that is available on the NI-Sync download page.As an alternative, you can implement the IRIG-B on an FPGA device like a cRIO, sbRIO or FlexRIO using the example attached in this document: IRIG-B Implementation in LabVIEW FPGA.
To get started with PXI/PXIe-6683, refer to the example called Set Time Reference.vi located here :
C:\Program Files\NI\LVAddons\nisync\1\examples\instr\niSync\Time-Based\Advanced
