I Cannot See the Single Pass and Test UTTs Buttons in My User Interface
Updated Jul 20, 2020
  • TestStand
I'm working with a custom User Interface to execute my sequence files developed with TestStand, but I cannot see the Single Pass and Test UTTs buttons, why?
The functionalities of the Single Pass and Test UTT buttons depend of the process models, please check that these files are installed in the following path <Users>\Public\Documents\National Instruments\<TestStand>\Components\Models\TestStandModels.
If needed to can copy the process models from your development computer.
To avoid this kind of issues, you can use the TestStand Deployment Utility  to deploy all the required files from your development to your deployment systems. For additional suggestions refer to TestStand System Deployment Best Practices.
