This issue occurs when
Open FPGA VI Reference is set to run in a
Dynamic mode. To select individual FPGA VI cluster elements, follow these steps:
1. Right-click Open FPGA VI Reference and select Configure Open FPGA VI Reference
2. Disable the
Dynamic Mode by unchecking the relevant box
After this, the individual cluster elements should be available, as seen below:
