Launching TestStand with an Environment File
Updated Jul 24, 2025
  • TestStand
I would like to launch TestStand with a specific environment file on launch, without using the graphical interface. Is this possible?
TestStand supports launching with a specific environment using a command-line argument. This is useful for automation, recovery from corrupted environments, or switching between configurations.
Use the following syntax to launch TestStand with a specific .tsenv file:
"C:\Program Files\National Instruments\TestStand 20XX\Bin\SeqEdit.exe" /env "C:\Path\To\YourEnvironment.tsenv"
Replace:
  • 20XX with your TestStand version (e.g., 2021)
  • "C:\Path\To\YourEnvironment.tsenv" with the full path to your environment file
To launch TestStand using the global environment, you can either execute SeqEdit.exe without the /env switch or use an empty path as shown below:
SeqEdit.exe /env ""
For TestStand 2021, to launch an environment file saved within a TestUser user documents as environment.ini:
"C:\Program Files\National Instruments\TestStand 2021\Bin\SeqEdit.exe" /env "C:\Users\TestUser\Documents\environment.ini"
