I am trying to use a Property Loader step to dynamically create and import variables and their values during sequence execution from a flattened NI Tab Delimited Text file. This file has the following structure inside:
<PropertyGroup name='Group 1' id='f7f779d0-7286-461e-916f-5323529306e7' description='Description for Group 1'>
<Category> <PropertyLookup> <Value>
{FileGlobals} VariableContainer.NumberVariable {Number} 0
{FileGlobals} VariableContainer.StringVariable {String} "SampleString"
{FileGlobals} VariableContainer.BooleanVariable {Boolean} False
<PropertyGroup>
I have set up the Property Loader step to import all properties from the source file and to create the required properties when they are not present in the destination, as illustrated below.
When the step executes, it returns a Run-Time Error with Error Code -17500 and the following description:
Error in Property Loader Source 'Source 0'
Unable to create 'FileGlobals.VariableContainer' since it does not exist in the Property Loader Group with id 'f7f779d0-7286-461e-916f-5323529306e7' and name '' in the source. Unselect the property to import or include the property in the source.
I have noticed that if at least one variable within the container or the container itself is created in the sequence beforehand, the error doesn't occur.
