Error 5906 Invalid File Handle in DIAdem
Updated Aug 8, 2022
  • DIAdem
I am trying to write to a file using a script in DIAdem, however I get the following error when it executes:
Error number: 5906
The specified file handle is invalid
5906 error
The file reference is not being properly created, so the error will be reported once the script tries to write to the file.
This can happen if you are trying to create the file in the root of the C:\ drive, without having the proper permissions to do so. In this case you can avoid the error by:
  • Launching DIAdem as administrator and then execute the script.
  • Change the location of the file elsewhere where your user has permissions to write, for example to your user's Desktop or Documents folder.
For the error message to be shown you need to use error handling in the script, you can refer to the DIAdem's help page for more information. The TextFileError and TextFileErrorTxt functions can be used to display information about text files errors.
