Custom devices enable you to customize and extend the functionality of NI VeriStand by packaging LabVIEW code, or any code you can call from LabVIEW, into a "device" that you can add to an NI VeriStand system definition file and deploy to a target.
You can
create a VeriStand custom device to deploy on a real-time target or
troubleshoot NI VeriStand Custom Device to debug and improve its functionality and performance.
To use FPGA and Real-Time Scan Resources, it is necessary to use the NI VeriStand Scan Engine Custom Device.
This article is a part of a series on
Troubleshooting VeriStand Guide. Refer to the main page for initial troubleshooting steps and find the possible cause of the issue you have.
