NI VeriStand can be used to interact with models from a variety of modeling environments and programming languages. NI VeriStand can run compiled models created in any supported modeling environment.Before you add and configure a model in NI VeriStand, you must compile the models to use them, and then you can use the model execution channels to interact with the models. Use system channels to monitor system parts, such as the host computer, the target, and the VeriStand Engine, while it is deployed and running.This article is a part of a series on Troubleshooting VeriStand Guide. Refer to the main page for initial troubleshooting steps and find the possible cause of the issue you have.
