Troubleshooting VeriStand: Software Issues
Updated Dec 18, 2023
  • VeriStand
  • TestStand
  • VeriStand Model Generation Support for LabVIEW
  • Simulink
  • MATLAB
The VeriStand framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, TestStand, and other software tools.
In this section, we will discuss issues causing a VeriStand Software crash and issues when integrating other Software.
This article is a part of a series on Troubleshooting VeriStand Guide. Refer to the main page for initial troubleshooting steps and find the possible cause of the issue you have.
VeriStand Crashes
  • Some issues can cause a software crash during the process of executing the tasks. Start searching for the cause of the crash by troubleshooting VeriStand Crashes.
  • If you are using the Hardware Discovery Wizard and you are receiving the Error -2147220623, be sure that you are selecting the controller in the System Definition before launching the Hardware Discovery Wizard.
Other Software Integration Issues
VeriStand can be used with the integration of other software and programming environments like LabVIEW or application software like TestStand. These can be used to help execute tasks that are impossible or harder in VeriStand. During the development, there can occur several issues related to software. MATLABĀ® is a registered trademark of The MathWorks, Inc.
