1. Setup the compiling toolchain Using the NI Linux Real-Time Cross Compile Toolchain with Visual Studio Code for Linux RT and Generating a Windows Dll File for Custom Checksum with Visual Studio for Windows.
2. Prepare the C code file 'NIXNETCustomInterfaceCAN.cpp' that contains your checksum (CRC) algorithm. The following screenshot is an example of a checksum algorithm. The checksum signal is byte7 and the checksum algorithm is that checksum = U8 (byte0 +byte1 +byte2 +byte3 +byte4 +byte5 +byte6)
In the if condition, "nxFrame->Identifier == 0x128" means that only the frame 0x128 will add this checksum algorithm. "nxFrame->Payload [7] != 2" means that if the value of checksum signal is equal to 2, the defined algorithm won't work. it is a way to insert the fault of checksum.
Without the condition of "nxFrame->Identifier == 0x128", the specific checksum algorithm will add to all the transmission frames.
If you don't want to insert the checksum fault for the frames, you can remove the condition of "nxFrame->Payload [7] != 2".
3. For Linux RT, Compile the NIXNETCustomInterfaceCAN.cpp to libNIXNETCustomInterfaceCAN.so file without any errors.
The so file can be found in the folder "......\build\bin\"
For Windows, Compile the NIXNETCustomInterfaceCAN.cpp to a dll file. The dll file can be found in the folder "......\x64\Release\".
4. Using WebDAV to Transfer Files to Real-Time Target - NI to copy the .so file to your RT target, e.g. ‘/c/ni-rt/NIVeriStand/Custom Devices/NI VCOM/libNIXNETCustomInterfaceCAN.so’ and configurate the VCOM configurator as following screenshot.
For Windows, the NIXNET Custom Interface is as follows.
