C Series Module Not Showing Under cRIO Hardware in SystemLink Server
Updated Jun 27, 2025
  • CompactRIO Controller
  • SystemLink Server
 I'm trying to check my C Series modules in SystemLink using the Devices and interfaces section of the Systems option from the Systems Management tab. I'm using a cRIO controller 9039, is there a way to check my plugged modules in the controller?
 Unfortunately, only cRIO controllers that support NI-DAQmx, like 904Xs and 905Xs, will show the details related to the plugged C Series modules.
Here is an example of the Devices and interfaces of a NI-DAQmx-supported controller:
The following is an example of a cRIO controller that doesn't support NI-DAQmx:
As a workaround, you can manually include the C Series module as an asset using these instructions with the SystemLink Asset Module.
