Can USRP-29XX Be Configured to Use Different I/Q Rates at Different Channels?
Updated Sep 28, 2023
  • USRP Software Defined Radio Device
I would like to configure two different I/Q rates for both the transmission channels in a single USRP. Is it possible?
Unfortunately, no.
Different I/Q rates cannot be configured. Even if it is physically separated, if different I/Q rates to be set, the application will be prompting an error after the generations as below.
Setting different sample rates for the two channels require different write size for each channel, meaning that we will be using single channel write for each channel compare to use 2D array as channel input. This is not supported by NI-USRP API. It will throw the error below.
