Error 1667 Using Python Node and TensorFlow in LabVIEW
Updated Jun 18, 2024
Programming Language
  • Python
LabVIEW shows the error 1667 when I use the Python node to call a Python function that imports the TensorFlow module because Python returns the error "AttributeError: module 'sys' has not attribute 'argv'.
To solve this specific Python error:
  1. Make sure that you have installed Python version 2.7 or 3.6.
  2. Copy the following piece of code:
                                                              import sys
                                                              if not hasattr(sys, 'argv'):
                                                               sys.argv = ['']
  1. Paste the copied code into the library "multi_process_lib.py" that is located in the following path:
             C:\Users\YOUR USER\AppData\Local\Programs\Python\Python36(or 27)\Lib\
             site-packages\tensorflow\python\distribute
The final code should look like this:
Note: Make sure that the line sys.argv = [''] has an indentation (a whitespace from the beginning of the row) you can do it if you place your cursor on the beginning of this row and press tab on the keyboard.
  1. Save it and run again the LabVIEW program.
