This issue typically occurs following a communication drop or a power cut/loss in the system environment that desynchronizes the host software and the C Series modules
Review your network environment settings such as IP address, subnet mask, and gateway for both the PC and CompactDAQ. If you set static IP addresses on these devices instead of using a DHCP server for automatic assignment, ensure they are unique across the network. A detailed guide with additional troubleshooting steps can be found in the article Troubleshooting Network cDAQ Connectivity Issues.
For maximum reliability and performance, also consider using a dedicated network to communicate with the CompactDAQ and other control and acquisition devices, isolated from the corporate network and its traffic
To recover the system and return the chassis to a synchronized state, perform one of the following reset methods:
Reset in NI MAX
- Open NI MAX
- Expand My System>>Devices and Interfaces>>Network Devices and select your CompactDAQ chassis.
- In the top toolbar, click Reset.
Note: The Reset button performs a software-level initialization of the driver layer, aborting active tasks and returning internal registers and C Series modules to default states without rebooting the chassis operating system or changing the IP address
Physical Reset Button on the Chassis
- Press and hold the physical Reset button on the CompactDAQ chassis for less than 5 seconds to trigger a cycle-reboot.
Caution: Holding the button for 5 seconds or longer restores the chassis to factory defaults and wipes user network configurations, including static IP address settings
Programmatic Reset in Application Code
- Use the NI System Configuration API in LabVIEW to reset the device programmatically when recovering from a power cycle or disconnection.
- Call the Reset Resource VI targeting your CompactDAQ chassis resource
