Disable Kernel DMA Protection to Avoid BSOD When Using NI-MXI Card
Updated May 6, 2026
The Blue Screen of Death (BSOD) can happen due to multiple reasons when involving MXI cards as we are depending on multiple manufacturers of motherboards and computers. For this article, we are tackling the issue when the stop code of the BSOD is specifying that it has a Driver Verifier DMA Violation error shown.
The specific steps to disable kernel DMA will vary for every different manufacturer BIOS. Please refer to the manufacturer's user manual for your specific PC if available, as that will usually be the best reference. Otherwise, the general steps to do so are as shown below:
  1. Boot into BIOS, this can be done by rebooting your PC and press F2/Delete, it will show up on your screen before Windows comes up.
  2. Then if you are able to boot in, you will land on the BIOS page. Usually, this DMA setting will be under Security Tab.
  3. Below is an example image. It might look different on your screen. Choose the Kernel DMA Protection and then select Disabled.
  1. Another thing that you can set to Disabled in the BIOS is the Intel Virtualization Technology for I/O (VT- d) if you don't have the option to disable Kernel DMA Protection. (VT-d settings can be found under Advanced CPU Settings)                 thumbnail_IMG-0246.jpg
  2. Select "Save and Exit" and then reboot your MXI PC.
