VeriStand Add-on Is Not Visible In LabVIEW
Updated Sep 28, 2024
  • VeriStand
I have installed LabVIEW and VeriStand following the order mentioned in the knowledgebase Installation Order for Multiple NI Software Products. But I am still not able to see an option to create a model for NI VeriStand using LabVIEW Development System.
You need to ensure that the VeriStand Model Generation Support Add-Ons is installed. You can check its availability in NI Package Manager (NIPM).
If it is not in the Installed tab, you can go to your Packages tab and choose to install them.
