Multiple Demo ECUs With ECU Measurement and Calibration Toolkit
Updated Apr 26, 2023
  • ECU Measurement and Calibration Toolkit
How can you run multiple instances of the Demo ECU vi, to simulate an ECU on a CAN interface?
The ECUMC Demo ECU CCP.vi and the ECUMC Demo ECU XCP.vi can be found in LabVIEW under Help>>Find Examples...>>Toolkits and Modules>>ECU Measurement and Calibration>>Demo ECUs
The ECU Measurement and Calibration Toolkit for LabVIEW provides a Demo ECU which can be used to test out the examples which are provided with the toolkit. The Demo ECU simulates an ECU on a CAN interface on a CAN module, so each instance of the Demo ECU will need a separate CAN interface and a separate operating system. So, for two Demo ECUs, you need two separate operating systems to run them on.
