Why does RFSA soft panel not recognize PXIe-5831
Updated Nov 8, 2022
  • PXIe-5831
  • NI-RFSA
  • NI-RFSG
When you download and install the latest driver RFSA 21.8 , open the RFSA Software Front Panel , the soft panel will prompt that the corresponding device cannot be found; but in NI MAX we can see the PXIe-5820 and PXIe-3622 , and both are Ready; why is this?
You look at the Readme of RFSA 21.5 and find the following description:
Therefore, you can see that the RFSA driver and the corresponding API support all VST/VSA devices, but the NI-RFSA Software Front Panel only supports some devices; the same is true for the corresponding RFSG SFP, which can be viewed by referring to the RFSA Readme document;
The Readme file of RFSA 21.8 does not have an introduction to the Supported Hardware section, but you can see the feature differences between RFSA 21.8 and RFSA 21.5; So you can see that the Support Hardware list of RFSA has not changed, just refer to the Readme information of RFSA 21.5;
In addition, RFmx SpecAn software supports PXIe-5831 and other devices, and SpecAn is also free software, it is recommended to use RFmx SpecAn instead of RFSA SFP;
