Accessing USRP-RIO AUX IOs
Updated Jan 15, 2026
  • USRP Software Defined Radio Reconfigurable Device
  • USRP-2950
  • USRP-2952
  • USRP-2953
  • USRP-2954
  • USRP-2955
  • USRP-2974
  • USRP-2940
  • USRP-2942
  • USRP-2943
  • USRP-2944
  • USRP-2945
  • NI-USRP
The NI USRP RIO devices have an AUX IO connector on the front panel with 12 general-purpose I/Os (GPIOs), one 3.3V, and two ground pins available. These IOs can be used for several purposes such as importing or exporting triggers for timing and synchronization with other USRPs or software-defined radios (SDRs), power amplifiers (PA), etc. Also, these IOs can be used to implement digital protocols, for example, UART for interfacing with accelerometer or GPSDO. This article will provide the basic steps of reading and writing to the USRP RIO AUX IOs using LabVIEW FPGA.
We can read or write to the USRP RIO I/Os in a similar way as we do for any other NI RIO target. Please note that the custom use of these USRP RIO AUX IOs is only possible when using LabVIEW FPGA-based Instrument Design Libraries for the USRP RIO devices. The USRP host driver APIs do not provide access to these IOs.
Following are the basic steps to expose these I/Os in your LabVIEW project:
  1. Create NI-USRP Simple Streaming project that enables FPGA-based programming of USRP RIO devices.
  2. In your LabVIEW NI-USRP Simple Streaming Project, you can find the GPIO lines under the FPGA target in Resources>>AUX I/O folder as shown below.
Table  Description automatically generated with medium confidence
If the AUX I/O folder is not automatically visible under the LabVIEW project, right-click the FPGA target>>New>>FPGA IOs and select AUX I/O from the available resources to include them in the project.
To use these GPIO resources, follow these steps:
  1. Pick the AUX I/O resource (from the LabVIEW project) you want to use and place (drag and drop) it on the block diagram.
  2. To read from the AUX I/O, the FPGA I/O node parameter's direction have to be set as shown below.
  3. When you want to write the digital value, the direction should be set as shown below.
A picture containing graphical user interface  Description automatically generated
  1. You can change the access mode of the USRP-RIO I/Os by right-clicking the FPGA I/O node and choosing the option Change to Write or Change to Read as shown below.
Graphical user interface, application  Description automatically generated
  1. To apply these changes to USRP-RIO, you must recompile the FPGA file. After completing the FPGA compilation, you can control these parameters on your host code.
Additional Information:
  • The USRP RIO AUX I/Os are directly connected to the Kintex 7 FPGA and have the same current source/sink limitations.
  • The AUX I/O 0 is also used by the USRP driver inside triggering APIs and should be avoided.
  • For transmitting or receiving the digital IQ data using Aux IOs, you will need to develop a parallel or serial protocol on your own. On the other hand, you can also use the MXIe link if IQ data has to be transferred to the host PC or 1/10GbE or Aroura (SFP) Links for data communication to an external host. Please consult the documents indexed in the related links
