Legend Word Wrapping for DIAdem VIEW
Updated May 31, 2023
  • DIAdem 2019
  • DIAdem 2018
  • DIAdem 2020
  • DIAdem 2021
  • DIAdem
After DIAdem 2019, the Legend section of the 2-D Axis system in VIEW has a Scroll bar by default and the properties are separated.
Is it possible to return to a Legend section in VIEW without the Scroll Bar and the Properties wrapped (As before the 2019 Version)?
From DIAdem 2019 you can select the option to go back to the previous display selecting the option.
VIEW > Settings > Layout Parameters
And enable the option Word wrap
  You should see a wrapping of the properties in the Legend.
