In the following external link, you can find a list of the files for LabVIEW projects that are safe to ignore for version control:
LabVIEW.gitignore.
The list also applies to the G Web Development Software, additionally, you can ignore the Builds folder since it contains the generated content related to a web application. Since it is a directory, you should use the following format: Builds/
