Viewing All Conditions of Case Structure at the Same Time in LabVIEW
Updated May 12, 2026
I want to see all conditions of case structure at the same time in LabVIEW for a better understanding of which Subdiagram(case) will be executed during our program work.
LabVIEW is a graphical programming environment, it is not intended to show all case structure conditions at once.
Therefore, it is not possible to view all conditions of the Case Structure at the same time.
You can see the case structure condition, by changing the case structure selector label.
Above, we see two different subdiagrams (cases) that will be executed under different Boolean conditions.
It is more typical of text-based programming languages, due to the lack of a graphical interface.
