Satellite communication is a crucial area where data transmission happens between the satellite and the ground station in wireless mode. Data quality is essential for these applications. The Consultative Committee for Space Data Systems (
CCSDS) has formulated the standards to make sure the data communication happens without any loss. The systems that are deployed on the ground station are called Telemetry Receivers. The receiver's functionality is to Down-convert the IF signal received and apply PSK Demodulation on it. The baseband data thus obtained is Decoded and Frame Synchronization is done to provide the actual data to the user for analysis. Telemetry is the process of receiving data or measurements from a remote location to the ground control station.
The outcome of this article is to provide the user with knowledge of satellite communication and provide the steps for configuring a Low Data Rate Telemetry Receiver using
NI LabVIEW and
NI Modulation Toolkit to develop the Telemetry Receiver application.
Prerequisite
A basic knowledge on Telemetry System & Satellite Communications and Modulation-Demodulation is required to understand the concepts. LabVIEW programming and NI hardware tool understanding is required.
