Current direction of SLSC-12251
Updated Aug 16, 2022
  • SLSC-12251
I am using SLSC-12251. I am considering a configuration in which current flows from the DUT terminal to the Bus terminal or vice versa. Is there a limit in the current direction of SLSC-12251?
As you can see from the schematic outline below, there is no limit to the current direction in SLSC-12251.
SLSC-12251 Circuit Overview
