Unable to Deploy VeriStand Project with SLSC-12001 due to Error -230839
Updated Jul 5, 2022
  • SLSC-12001
  • VeriStand
I've created a new project in VeriStand in which I've added only SLSC-12001 chassis and modules to the System Definition File. When trying to deploy the project it returns error -230839:
Error -250839 occurred at Project Window.lvlib:Project Window. vi > > Project Window.lvlib:Command Loop. vi > > Project Window.lvlib:Connect to System. vi
Possible reasons(s):
"The specified network host is unreachable"
What is causing this error and how can I fix it?
NI Switch Load and Signal Conditioning (SLSC) extends the PXI or CompactRIO platform with the ability to add custom front-end modules. When deploying a VeriStand project with SLSC modules added to the System Definition File, it results in error -230839 "The specified network host is unreachable" that's means there is problem in the network communication between Real-Time controller and SLSC.
Therefore, it is necessary to check if both devices belong to the same subnetwork.
  • In the picture below SLSC-12001 Network Settings Tab:        slsc_config.PNG
  • In the picture below Real-Time Controller Network Settings Tab:        pxie conf.PNG
You can achieve such result following the Knowledge Base Setting Up the SLSC Extension of a Real-Time Controller - Step 4.
