What Is the Synchronization Accuracy of the PXI-6683?
Updated May 26, 2022
  • PXI-6683
I have a PXI-6683 and I would like to know which synchronization option has the highest accuracy and how the synchronization performance of the different synchronization technologies compare
The Synchronization Accuracy depends on the technology you are using. The table below shows the synchronization accuracy for the different synchronization approaches you can take with the PXI-6683.
