This error occurs when the LabVIEW Development System is selected as the execution environment. To resolve the issue, switch to the LabVIEW Run-Time Engine.
If you are using the Full-Featured User Interface of TestStand:
Open the User Interface.
Go to the Configure menu and select Adapters.
In the pop-up window, click Configure next to the LabVIEW adapter.
Select the LabVIEW Run-Time Engine and click OK.
If you are using the Simple User Interface of TestStand:
There is no built-in option to change the adapter in the UI. To resolve the issue, follow these steps:
On the development machine, set the LabVIEW adapter to use the Run-Time Engine.
Locate the Adapters.cfg file (typically found in the TestStand configuration directory).
Manually copy the Adapters.cfg file to the corresponding directory on the deployment computer.
Launch the application again.
