This article guides on configuring the PXI-2510 Fault Insertion Unit (FIU) using NI VeriStand 2020 R6. To insert fault conditions, internal relays are configured to create short-circuit connections and open circuits. The automated test applications commonly use the following fault conditions:
- No-Fault /Pass-Through Operations
- Open Circuits Faults
- Short to Ground
- Short to Power
To know more about the Fault Insertion Applications, refer to
NI VeriStand Add-on - NI Fault Insertion Unit. Once the configurations are performed correctly, users would be able to use FIU to insert fault conditions between the real-time hardware-in-the-loop (HIL) simulation systems and the Device Under Test (DUT). This article is intended for the audience who works closely with HIL Validation Systems.
Prerequisite knowledge is required for:
