How to Rotate an Image in Vision Builder an Automated Inspection?
Updated May 20, 2022
  • Vision Builder for Automated Inspection
I am not able to find the step that allows me to rotate an image.
It is possible to rotate an image through the Vision Assistant Step in VBAI>>Inspection Step: Enhance Image>>Vision Assistant.
Then will be necessary to select the ROI (which can be the entire image if necessary) and click on the Edit button.
Immediately the NI Vision Assistant shows up with the Geometry>>Rotation step available.
