Greyed Out Message When Importing an Simulink Model into Veristand
Updated Jul 28, 2026
  • VeriStand
I am using VeriStand 2021 or later with the VeriStand Model Generation Support [EXTERNAL LINK] add-on.
I can build or compile my model, but when adding the model through the UI Manager/Mappings diagram the model block appears greyed out and hovering my mouse over the blocks shows:
Item not found. Repair the linkage or remove the broken item.
NI VeriStand: The input file parameter is invalid or does not exist.
Details: *Path to the Model*.vsmodel
modelgreyedout.jfif
This error occurs when you have used incompatible versions of VeriStand and the VeriStand Model Generation Support' MATLAB add-on.  Make sure to verify compatibility at: VeriStand Model Generation Support and MathWorks Simulink® Compatibility
If you are using VeriStand 2021, this is compatible with version 1.0 of the 'VeriStand Model Generation Support' MATLAB add-on, but not version 1.1.
Either upgrade your version of VeriStand to 2021 R2 and continue using version 1.1 of the add-on. Or, uninstall the add-on and instead install version 1.0.
VeriStand  MathWorks MATLAB®  VeriStand Model Generation Support
2021 R3R2022a/b
R2021a/b
R2020a/b
1.2 [EXTERNAL LINK], 1.1*, 1.0*
2021 R2R2022a
R2021a/b
R2020a/b
1.1 [EXTERNAL LINK], 1.0*
2021R2021a/b
R2020a/b
1.0 [EXTERNAL LINK]
*Previous versions of VeriStand Model Generation Support are compatible with newer versions of VeriStand, but may not include the newest features.
Through the MATLAB Add-On Explorer you can only install the latest version of the 'VeriStand Model Generation Support' add-on. If you require an older version, you can get this from the VeriStand GitHub page:
Releases · ni/niveristand-model-generation-support-for-simulink · GitHub
Select the version you require and then download and run the VeriStandModelGenerationSupport.mltbx file.
Another root cause for this behavior is having a NaN in a matrix operation. If the variable array contains a NaN value somewhere in the array, even if it is not referenced at all by the Simulink model, the model will fail to load in VeriStand. The values or size of the array doesn't matter, but it should contain NaN in any spot other than the 0th element. As a workaround,  you can swap out these matrix-indexed values for unique workspace variables derived from those matrices
