Bus Log Converter Error When Converting a Log File Using DIAdem
Updated May 5, 2025
  • DIAdem
I am trying to decode or convert a log file to be able to analyze it using DIAdem. I already opened the Bus Log Converter and selected the log file and the appropriate database file, but I keep getting the following error message:
Bus Log Converter error: Cannot create TDM file with the current settings.
Possible causes are signal database assignments, time range, signal filters or
bus filters are unsuitable or the data set does not contain any frames to be
processed.
You can create the Bus Log Converter configuration file (*.tcc) by following these steps:
1. Open DIAdem and from the NAVIGATOR panel, go to File >> Bus Log Converter.
2. Configure the settings of the Bus Log Converter window by selecting the appropriate file type and filename by browsing to the location of the log file.
3. Configure the signal database by going to the left panel and clicking on Signal Databases under Configuration.
4. In the Signal databases panel click on the "+" symbol (Add Bus Database Assignment) to add the database file.
5. In the Bus Database Assignment window click on the "+" symbol (Add Database File) and browse to the location of the .dbc file that you want to use. Once you have found it select it and click Load.
6. Once you have loaded the .dbc file make sure to select the appropriate ID-Mode. You can determine the ID that you need to select by opening the .dbc file in a text editor and searching for the "ProtocolType" or "BusType" keyword and selecting it as the ID. It is not recommended to leave it with the default option since it may fail to convert the file.
7. Click on Convert to load the file into DIAdem or save the *.tcc file by clicking on the third top left icon, as shown in the image below.
If you cannot identify the cause of the error, please contact NI Technical Support and provide the log file and the .dbc file to reproduce the error.
Please note that the Bus Log Converter only supports signals where Bus numbers are present.
