Use NI DataPlugin in Visual Studio
Updated Sep 28, 2023
  • LabVIEW DataPlugin SDK
I have created DataPlugin (.uri) file with LabVIEW software to read the binary file. Once DataPlugin is registered, I can see my test file data using DIAdem software. May I know if it is possible to use the DataPlugin that I have created in Visual Studio?
Currently, there is no way to use DataPlugin alone outside DIAdem, DataFinder or LabVIEW.
The workaround that you can explore is use LabVIEW to build a library (DLL) to do the conversion and use this library from your C++ project to read the binary file, you can refer to Generate a Shared Library From a LabVIEW Project to get started. You might need to install the LabVIEW runtime engine to use the LabVIEW DLL.
