How Do I Perform an Offset Null of My DMM in LabVIEW
Updated Nov 1, 2022
  • PXIe-4080
  • NI-DMM
The NI DMM driver does not have a function to perform offset nulling, for that reason it is necessary to implement this feature programmatically. This article will go through the steps to create a simple code to do a null offset.
You need to have NI DMM installed and the respective ADE.
1) Open a session to the DMM.
2) Configure the range the resolution and all the other parameters of your DMM.
3) Initiate the DMM.
4) Read just one sample (this is the offset for the future samples).
5) Read your data.
6) Subtract from your data, the offset previously read.
After following those steps you should have a code similar to the below one.
