Display a Login Page for LabVIEW Web Service Static Content
Updated Oct 30, 2023
This article demonstrates how to apply the User Roles and Permissions settings of a LabVIEW Web Service to it's associated static content, such as HTML pages.
This can be useful if a login page is required to access any static content within a Web Service for security reasons.
To  apply User Role and Permission settings, and therefore display a login page for static content, follow the steps below:
1. Refer to Configuring User Permissions in NI Auth for LabVIEW Web Services and complete steps 1 to 11.
  • These steps describe how to define security configurations for different Web Servers.
2. In LabVIEW, add a Web Service to the project.
  • If the Web Service runs on the local PC, right-click My Computer and select New >> Web Service.
  • If the Web Service runs on a real-time target, right-click the target and select New >> Web Service.
3. Add a HTTP Method VI to the Web Service. 4. Add static content to the Web Service.
  • Right-click the Web Service in the LabVIEW project tree and select Add Public Content Folder...
  • In the file explorer window, select the folder to associate with the static content. Note: the LabVIEW folder will auto-populate with the content of the local folder.
5. Configure the static content to use security permissions.
  • Right-click the Web Service and select Properties.
  • In the Web Service Properties window, navigate to the Service Settings tab.
  • Under the Static Documents section, enter the name of the permission(s) configured in step 1 of this article.
  • Press OK.
6. Publish the Web Service.
  • Right-click the Web Service and select Application Web Server >> Publish.
7. Access the static content in a browser and verify that valid credentials are required.
  • Expand the Public Content folder, right-click the static content file and select Show Public URL...
  • Copy the URL and paste it in a supported browser.
  • Clients should be greeted by a login prompt similar to the image below. Note: the static content will only load correctly if the username and password match the list of approved users.
