Error -8014 When Using NI ADCS Toolkit With NI-985x
Updated Oct 23, 2023
  • NI-9853
  • NI-9852
  • Automotive Diagnostic Command Set Toolkit
When I follow the steps How to Do UDS Test With CompactRIO and NI-985x, I get the following error:
  • Make sure that you have transferred the FPGA bit file into the C folder of CompactRIO target.
  • You may have a permission issue. You can try to read the FPGA bit file using File I/O VIs. If error 8 is thrown, you don't have the correct permissions for the file, please put the bit file in another location of the CompactRIO target and try again.
