Error (Hex 0xBFF63167) When Deploy Project in VeriStand
Updated Oct 20, 2022
  • PXI FlexRay Interface Module
  • VeriStand
I am trying to deploy a project in veristand. However, i get an error message as shown below:
NI-XNET: (Hex 0xBFF63167) There is not enough message RAM on the FlexRay hardware to configure the data partition for the object(s). Solution: Please refer to the manual for limitations on the number of objects that can be created at any given time based on the payload length.
The root cause for errorĀ 0xBFF63167 occurs is when trying to create too many objects either frames or PDUs on one interface at the same time.
The limit is only 128 objects.
