There is no built-in interface in FlexLogger to interactively change CAN FD baud rate settings or other settings like the ones indicated in
CAN Interface and Database Settings, however, you can modify these in your database using
NI XNET Database Editor and then import the changes into FlexLogger.
To import the changes from your
Channel Specification tab in your FlexLogger project:
1. Click
Add signals under the CAN Interface Module you want to use.
2. Choose the
Database and
Cluster you want to import the settings from in the corresponding drop-down menus and configure
Direction and
Application protocol if needed.
3. Select the checkboxes for the signals you want to add.
