In order to generate Pulse Modulation signal through a Quicksyn frequency synthesizer, the below conditions must be satisfied -
- The synthesizer must have Option 5 enabled. This can be verified by referring to a sticker on the synthesizer's body or through the QuickSyn Soft Front Panel GUI. If this option is not enabled, contact your local NI Account Manager for upgrade options.
QuickSyn Device Sticker
- You must provide an external CMOS compatible signal on the PULSE SMA connector on the device.
- You must enable the Pulse Modulation boolean button on the QuickSyn Soft Front Panel -
