Display Text and Picture Ring as One Indicator
Updated Nov 29, 2023
I want to display text ring and picture ring in one indicator. How can I do this in LabVIEW?
You can combine text and picture as one control or indicator by using the Text & Pict Ring function. To add a Text & Pict Ring, perform the following:
  1. Right-click on the Front Panel to open the Controls Palette.
  2. Navigate to Modern»Ring & Enum and select the Text & Pict Ring as shown in the image below.
  3. (Optional) To display it as an indicator, right click on the control and select Change to Indicator.
  4. To insert the picture to the indicator, you need to Add Images In LabVIEW.
  5. Right click on the indicator and select Import Picture from Clipboard as shown in the image below. The picture that you have added in step 4 will be automatically insert to the indicator. You can also manually insert the picture by dragging it into the indicator.
