Disable Logging for Certain Channels in FlexLogger
Updated Apr 23, 2025
  • FlexLogger
This article goes through the steps to disable logging for certain channels in FlexLogger. This is a feature that was introduced in the FlexLogger 2022 Q2 version.
This article assumes that you are familiarized with configuring channels and logging data within the FlexLogger environment.
Note: Currently this option is not available in the FlexLogger Plug-In Development Kit.
1. Open a FlexLogger project and go to the Channel Specification tab.
2. In the Channel Specification, hover over a channel and click Disable logging (icon disable logging.png). The channel will no longer appear bold. In the following image, you can see an example with an NI-9205, where the channels AI1 and AI2 have been disabled for logging:
3. If you want to disable logging for several channels at the same time, you can select multiple channels by holding shift or ctrl and clicking on the channels, and then on the Disable logging icon for any of them (icon disable logging.png). This will disable logging for all of the selected channels.
