Get the Number of Rows and Columns of a 2D Array With a Single LabVIEW Function
Updated Apr 29, 2024
When using the Array Size function on a 2D array in LabVIEW it returns the size of the array in a 2-element 1D array, I then need to use the Index Array function to get the number of rows and columns.
Is there a single LabVIEW function that returns the number of rows and columns in a 2D array?
You can use the Matrix Size Function to get the number of rows and columns of a 2D array of any data type. With this function, you will not need the additional step of indexing the resulting array.
