Improving The Dashboard Performance in NI SystemLink™
Updated Oct 23, 2026
  • SystemLink
  • SystemLink Server
Other
As NI SystemLink is an application software which NI continuously invests in, this article will be updated when there are changes in the following new versions. SystemLink 2023 Q3 is the latest version when this article was published.
This article will help you solve the inefficiency problems caused by introducing Notebook into the SystemLink dashboard and recommend alternatives for more efficient data presentation.
NOTES
  • SystemLink is an intelligent Systems and Data Management application software. Dashboard is one of the NI SystemLink Web Applications which allows you to display key metrics in one webpage.
  1. Reduce Notebook update interval as much as possible based on actual application scenario.
  • The first time a dashboard loads a notebook it will be executed. For any subsequent calls, it will return the cached value until the update interval expires the cache. At that point in time, it will execute the notebook again.
  • And the cache is per user. Every access from different users for the same dashboard will request a notebook execution to the SystemLink server which will increase the server load. The more notebooks applied in the dashboard; the more request will send to the SystemLink server.
  • It is recommended that the update interval should not be lower than one hour.
  1. Avoid creating dashboards that load data using notebook.
  • The dashboards will load much faster and have an overall lower impact on the server.
  • You could instead create a scheduled task to run once per hour and calculate the metric you want and then publish the results as tags that you can load into a dashboard.
  • Refer to API Reference - NI for how to leverage SystenLink API to customize the scheduled tasks based on your application scenario.
