How Can I Change the Password of My Real-Time Target?
Updated Aug 20, 2026
  • CompactRIO Controller
  • PXI Controller
  • Phar Lap
  • VxWorks
I need to change the password of my NI Real-Time target. How can I do that?
To change the password of your Real-Time (RT) target, you can consider the following options:
NI MAX
To change your RT target's password using NI MAX, follow these steps:
  • Press OK.
NI Hardware Manager
To change your RT target's password using NI Hardware Manager, follow these steps:
  • Press OK.
SSH
To change your RT target's password via SSH, follow these steps:
  • Make sure SSH is enabled in your target.
  • Establish an SSH connection to your target. Please refer to the Accessing the Shell on NI Linux Real-Time Devices knowledge article for detailed instructions.
  • Enter the passwd command.
  • Enter your current password. If you were not using a password before, press Enter.
    • Note: By default, Linux will hide the characters you are entering. Do not be concerned, as they are still being registered, even if you do not see anything written on your screen.
  • Re-enter your new password.
  • The following message will show up in the terminal: passwd: password updated successfully
