Adding Custom Glyphs to List Controls in LabVIEW
Updated Apr 29, 2024
Is it possible to add custom glyphs to tree controls and single/multicolumn listboxes in LabVIEW?
Custom glyphs can be added to trees and listboxes using the Custom Item Symbols:Set To Custom Symbol method. You can use this method with any image files, including the LabVIEW-specific icons in the following folder:
[LabVIEW 20xx]\resource\Framework\Providers\Icons
The following are examples for the different controls:
  • Tree Control
Note: This image is a LabVIEW snippet, which includes LabVIEW code that you can reuse in your project. To use a snippet, right-click the image, save it to your computer, and drag the file onto your LabVIEW diagram.
  • Listbox
  • Multicolumn Listbox
To ensure symbols are visible on the control, right-click the control and select Visible Items>>Symbols.
