What Is CDR In QSFP?
Updated Jan 15, 2024
  • QSFP+ Optical Transceiver
I am not sure what CDR means when I use optical cable module and want to program it in LabVIEW.
CDR is clock data recovery. It's a circuit inside optical cable module which captures the data to retransmit it through the cable.
We can see the memory map of the cable's management interface of SFF-8636 from https://members.snia.org/document/dl/26418.  Write QSFP VI and Read QSFP VI are provided in LabVIEW to read and write to the cable's management interface. For example, writing 0x00 to address 98 will disable all TX and RX CDRs:
