If, Then, Else Programming in FlexLogger
Updated Dec 26, 2023
  • FlexLogger
I would like to realize an if, then, else programming in FlexLogger and I don't know how to implement it.
I want to display a pressure. If p<0.1Pa, then p=0.1Pa should be displayed, else(p>0.1Pa) p=p should be displayed.
Is this possible with an arithmetic formula? Or is there another way to implement this?
The arithmetic formula channel supports the ternary operator which allows you to do it/else logic.  In this case, assuming the channel name is 'p', the formula would look like:
'p' < 0.1 ? 0.1 : 'p'
Or you could invert the logic and write it this way
'p' >= 0.1 ? 'p' : 0.1
