TBX-68 Pinout Details
Updated Dec 19, 2023
  • TBX-68
I would like to use a terminal block, TBX-68 with one of my PCIe cards. Unlike another terminal block SCB-68, I could not find any information regarding the pinout details for TBX-68. How can I use TBX-68?
TBX-68 maps to each of the 68 pins in the DAQ card directly.
Therefore, you need to refer the pinout of the card instead to match the pins. For example, if you are using PCIe-6323 with TBX-68, you need to refer the pinout of the PCIe-6323.
